Brief Description: Rivet right spar angles, SPARS ARE DONE!
I attached and riveted the right spar rib attach angles. After that I pulled down the rear spars and riveted the one hole that needed the 3/16 rivet (the one that I busted a drill bit in and ended up too big for a 5/32" rivet). I practiced setting several 3/16 rivets first. I tried using a Hand Riveting/Dimpling Tool but wasn't having much luck with it. I tried using the gun and a heavy bucking bar and that worked fine so that what I ended up using on the spar.
