Brief Description: Deburr rib attach angles, primer prep
Andrea helped me deburr the rib attach angles. I decided to attach a tag to each piece to identify them. After losing the markings for the vertical stiffeners I don't want to repeat having to sort though all the angles and try to relocate them correctly. I just attached a piece of tape to a string to mark them.
I cleaned all the parts with Acetone then soap and water. I then did the acid etch and Alodine treatment.
