The parts for the left side were match drilled and opened up the same as the right side was done. Everything except the vertical stiffeners are drilled. I used the end plates and sandwiched the spar web to mark and rough cut, then trim down to match the end plates.
Andrea wanted to get some stick time and it was a perfect day for it so we took time out to fly RC's.
