Waynes Bearhawks
Date:  6-3-2008
Number of Hours:  6.00
Brief Description:  Aux tanks
After a good discussion on the Bearhawk eGroup I've decided to have aux tanks. It wasn't my original intent so it took some time considering what I need to do. Since I bought my main tanks from AviPro I thought this might be a good project to do myself for the benefit of learning something new. I first needed to find someone that would be willing to help me and was lucky to find just the right person.
After putting together a material list I placed the order. The aux tanks will need a 4' x 6' sheet of .050 5052 H-32. Since the piece has to ship flat I ordered 2 sheets to have some extra on hand (in case I screw up!)
It was helpful having the AviPro tanks and I noticed they made them a little differently that the procedure in Bear Tracks. In Bear Tracks the top and bottom skins were 2 pieces but the AviPro tanks were one piece. That seems like a good idea with less welding. Also, they did not cleco the main skins to the ends, only the center baffles.
Following their example I cut and formed the ends and I made the skin in one piece. I made a master form from MDF just like the wing rib master form. I bent the main skin on the 36" brake after marking the bend directly off the end pieces.
Cutting the Ends
Cutting the Ends
Forming End
Forming End
Right Aux Tank
Right Aux Tank
