Brief Description: Lay out aileron spars, make attach angles
I cut the aileron spars to length and laid out the hinge and rib locations. I cut the pieces for the attach angles. The front are .025 and the rear are .032. I bent the angles in the mini brake. Then I drilled and deburred the holes in the angles.
