Waynes Bearhawks
4-Place Bearhawk
Center rib attach angles
I fit the center rib attach angles to the right spar. After fitting I removed them and drilled the holes on the rib side of the angle.
I went skiing again today and was too tired to do much more!
Center Rib Attach Angles Right Spar Outboard
Center Rib Attach Angles Right Spar Mid Area
Center Rib Attach Angles Right Spar Inboard
Bearhawk LSA Home
4-Place Bearhawk Home
2633
Ailerons
Aux Fuel Tanks
Flap/Aileron Hinges
Flaps
Flight Controls
468
Ribs
Spars
57
303
Tail
Wing Assembly
Wing Skinning
92
442
Wing Steel Parts
