Waynes Bearhawks
4-Place Bearhawk
Drill main spars
All the holes on both the left and right main spars were drilled to there final rivet size. I did the capstrips on the left side first, then the vertical stiffeners, then the plates. I then clamped the right spar and repeated the process.
Making Metal Shavings
Drilling the Right Side
Double Spar Cap Transition
Bearhawk LSA Home
4-Place Bearhawk Home
2633
Ailerons
Aux Fuel Tanks
Flap/Aileron Hinges
Flaps
Flight Controls
468
Ribs
Spars
57
303
Tail
Wing Assembly
Wing Skinning
92
442
Wing Steel Parts
