I made the link arm for the bottom of the sticks today. It's a pretty easy piece to make. I cut the end parts first and match drilled them to their mates then grinded and sanded the ends. Then I bolted the bushing in between the parts. Then I cut the tube to length and used the smoosh tool to press the ends to 1/4". Next was to tack/check/then final weld.
