"I finished fitting the diagonal tubing in the front between station P and O. I also cut out and replaced the one I fit and tacked the other day. When I tacked it I burned a hole in the edge and it was bugging me. I realized I was using the wrong tip on my torch. Now I'm using the #1 tip and having better success. I flipped the top over and tacked the other side. The top is done so I secured it off to the side.
With the fuselage top off the table I removed all the blocks and re-painted the table top. I'll start the bottom tomorrow."
