Waynes Bearhawks
Date:  4-5-2011
Number of Hours:  7.00
Brief Description:  Right main tank plumbing
"I started working on the plumbing for the right main tank. If I had to do it again I would leave a little more room on the inboard side of the main tanks. I centered them and it's a little tight for the fittings. The 45 degree fitting at the main tank aft is the most bothersome. I installed the tank to mark for the holes in the rib then remove the tank to drill and when I put the tank back in it seems like it moved. I can't seem to get the tanks to fit in the same spot twice. So after a little work I finally got it to fit. I must have removed and replaced the tank about 6 times though. Once the individual lines were made I had to remove the main tank one more time to fit them into place.
Next I plumbed the aux tank line to the main tank sight gauge line. I realized that I didn't plumb the left aux tank to main tank so I'm not quite done on the left wing yet."
Making Fuel Lines
Making Fuel Lines
Fuel Line with Fittings
Bothersome Fitting!
Bothersome Fitting!
