Bills Web Site
Date:  2-13-2010
Number of Hours:  2.50
Brief Description:  Elevator
Attached trim cover to bottom of elevator. Torqued counterweight bolts. Began rolling leading edges of the left elevator with the help of my lovely but clueless assistant, Jeanne. I used a 1" diameter broom handle and aligator tape. These hi-tech tools produce very good results. I quickly discovered rolling one section at a time is much easier. I inadvertently installed the bottom skin over the top only to discover my error. It only took a fiew minutes to drill out the pop rivets and correctly complete the installation. Installing the top skin over the bottom will shed water properly.
Rolling left elevator leading edge
Rolling one section at a time
Pop rivet installed after rolling top & bottom skin
