Brief Description: Finished up right aileron .. control surfaces done
Received the replacement aileron leading edge (along with another, smaller "snake coffin"). Deburred, drilled, dimpled and primed. Then, proceeded to build up the aileron, with the right pressure set on the gun. Went together smoothly.
Installed the aileron hinge brackets and torque the bolts.
