RV-7
RV-7
Weight and Balance
Weight and balance measurements. 7 qt oil, no fuel, all internal and exterior panels in place. No gear fairings; will add those later in phase one, initial flighs will be without gear farings.
Right wheel: arm: 69.20", weight 513 lbs.
Left wheel: arm: 69.50", weight 529 lbs.
Tail wheel: arm: 239.38, weight 64 lbs.
Empty weight: 1106 lbs
Empty CG: 79.77"
See associated W&B documentation for full CG workups for various loading configurations.
Aircraft CG limits per Van's documentation.
Fwd limit: 78.70"
Aft Limit: 86.82"
Aft limit (acro): 84.50"
Girl on the scales!
R main
Tailwheel level
RV-7 Home
2357
222
Finishing
93
533
Firewall forward
665
Service Bulletins
Tanks
308
