RV-7
Date:  1-27-2019
Number of Hours:  6.00
Brief Description:  Brake lines, gear leg fairings 1
Time to change gears - to the gear! I tried to lay in the brake lines, but found them to be too short! I orderd them form TS Flightlines, and after talking with Tom, it seems that they were fabbed incorrectly and should have had a 90 deg bend on one end. Tom quickly sent out a new set for free (Thanks Tom!); the sent back the originals ... perhaps they can be cut shorter for some other project.
Started to fit up the gear fairings. Lots of tuining and trying here .. the "do it on the plane" instructions seem practically impossible, so I did the drilling and install of the hinges on the bench. The right fairing got a bit too chopped up ... I'll reorder and redo.
Brake line too short!
Right gear fairing from the front
Back view...
Back view...
