RV-7
Date:  3-7-2015
Number of Hours:  8.50
Brief Description:  D&D fuse side skins, priming of fwd fuse parts
Deburred and dimpled both side skins on the C-frame; needed an extension table to handle the size of the skins. The ordeal was not as bad as I thought; fewer holes than the wing skins.
Following deburring dimpling/countersinking of the parts, they all went through an alumniprep bath and then primed with Stewart Systems smoke gray EcoPrime.
Dimping side skins
Dimping side skins
Post priming of internal stiffeners
The rest of the cabin stiffeners
