RV-7
Date:  3-22-2020
Number of Hours:  5.00
Brief Description:  Fuel flow testing
Fuel flow testing. Pump on; fuel line disconnected at servo, flow into calibrated fuel jugs. Fuel caps on and locked.
Level attitude:
L tank: 2 gal in 3:08 min = 38.3 gph
R tank: 2 gal in 3:04 min = 39.1 gph
3 point attitude (11 deg nose up)
L tank: 2 gal in 3:10 min = 37.9 gph
R tank: 2 gal in 3:12 min = 37.5 gph
Per Lycoming doc 60297-36, IO-360 Operators Manual, max FF at 180 HP / 2700 RPM = 16.4 gph.
Fuel flow margin: level = 38.3/16.4 = 235%
Fuel flow margin: 3 point = 37.6/16.4 = 229%
Fuel flow test successful! Pulled the 70 micron filter from in front of the pump and inspected for crud. Very small amounts of aluminum dust were seen with a magnifiying glass .. cleaned, safetied and reinstalled.
Checked the filer used between the fuel servo line and he jugs .. no contamination could be detected.
Fuel flow, level attitude
Fuel flow, front view
Clean filter after test
