RV-7
Date:  3-28-2020
Number of Hours:  6.00
Brief Description:  New fuel level sensors, rudder connections
Replaced the Dynon fuel capacitive sensors with Princeton 1S units. They original Dynons were very insensitive (seems to be a known issue); the Princeton units work much better ... higher output range.
Added the rudder cable / pedal links. 3" center to center is the initial setting based on hangar flying. Will test and adjust.
Princeton Capacitve fuel sensor installed
Rudder links installed
Airport mascot for the
Airport mascot for the "flightless plane"
