RV-7
Date:  11-23-2015
Number of Hours:  6.00
Brief Description:  Drilled the lower rudder attach holes
Drilled the lower rudder attach holes. VERY carefully triple checked edge distance into tailwhell weldment and drilled the holes up to 3/16; Need to go up to 1/4 for AN4 bolts.
Ran out of angle stock for the rudder stops; a Van's order will fix it.
Lower aft rudder spar.
