RV-7
Date:  3-29-2015
Number of Hours:  8.00
Brief Description:  Fuse reassembly2
Adjusted and reinstalled floor and floor stiffeners
Placed temporary 1.45 inch spacers in slots betweent the F-704 A and B bulkheads, loosly installed bolts and F-905 spacers between F-704 A/B. Double checked the rivet holes for 704 A/B to be sure when the rivets go in, the spacing will be locked in properly.
Finished up the fitting of the 623A attach straps for the F-623 corner rib on the baggage floor.
The armrests have been reported to be relatively fragile, so I decided to do a stiffening job per on of the threads on VAF and and add a bit of J-channel to the inside edge. This is an easy and light weight mod, and makes the arm rests much stiffer.
Stiffeners, drilled, dimpled and primed.
Stiffiner edge on
Stiffiner edge on
