Riveted together the brake pedals following priming. This was an easy job with the pneumatic squeezer.
Following riveting, the pedals were fitted to the rudder pedals. I found that he spacing between the mounting horns was a bit tight, and required some bending and other man handling to get them spaced properly for for the install.
