RV-7
Date:  12-31-2013
Number of Hours:  4.50
Brief Description:  Tank fitting and top skins cleco
Loose installed autopilot servo hard mounts
Fitted tanks and bolted/screwed them in place. Had some issues with a slight misalignment of the skins between LE and tank on the top side between the spar and first screw hole. Some investigaiton showed tha ajoining LE rib was slightly off center (I screwed up the first on the initial drill and and to replace it; it didn't quite get drilled the same. I tried adjusting it slightly, but once in place, the tank bolt holes didn't lline up very well. So, move it back (and re-riveted again!) and will have to live with it. It's cosmetic, and a litte bit of filler in the paint shop will fit it.
Clecoed on both skins -- getting ready for riveting.
Spacer for tiedown to skin gap
Spacer prosealed in place
Top skins on .. ready for riveting
