RV-7
Date:  3-12-2013
Number of Hours:  1.00
Brief Description:  HS fiberglass
Begin fitting HS and checking the alignent/gap. It seems that the measurement was a bit off trimmed the tips off a bit more than I would of like and the gap was a bit bigger than desired. I see if I can fill this after glassing the open end.
Prep up for closing the end with fiberglass
Gap between elevator and HS tip .. a bit big
Checking clearance
Checking clearance
