RV-7
Date:  3-2-2013
Number of Hours:  4.75
Brief Description:  Rolling the elevator LE
Worked on rolling the leading edges of the elevator. Used a 1" dia aluminum pipe and Gorilla tape to do the forming. I devised a clamp that would hold down the pipe so I could use a couple of screw drivers as handles - put one on each end of the pipe.
This worked very well and I could easly bend and align the leading edges for riveting. I could not find any of the frustration evident on VAF using this process. Easy, though it did take a bit of time to set up and patiently bend to the right amount.
Definitely gotta use Gorilla Grip duct tape ... that stuff really holds!
Magic hold down clamp
Resulting LE looks good!
