RV-7
Date:  12-23-2012
Number of Hours:  3.50
Brief Description:  HS completion
Built a tool to push the flang back into position for the installition of the pop rivets. I was able to inert a stick that pushed on the flange on one end and the forward spar on the other… making the hypotenuse of a triange between the rib and the forward spar, at a small angle between the the stick and the rib. This was pushed into positon, held in with a long stick and wedge in the open area between the HS halves, then the rivet was popped. Worked great .. and didn't have to remove the skin to fix
HS complete! 38.3 hrs"
HS complete
HS complete
Reverse angle
Reverse angle
