Brief Description: Horizontal stabilizer tip installation
Tonight I started the installation of the horizontal stabilizer tips. I riveted the tail tip rib into place and cut the fiberglass tip down to size using a dremel tool with a cutoff blade. Installed tip and drilled hole. Left side is ready to be prepped for paint.
