Today I finished the assembly of the elevator push rod tube. The push rod had to be adjusted to the correct length and then drilled and bolted together in three places. Drilled the push rod ends so the bushings would fit and connected push rods. I also installed the shield to cover the push rod that travels under the seat and the cross members that the elevator push rod travel thru. It is very cool to see the control stick assembly in action.
