Tonight I assembled the control stick assembly. I had to drill the two holes in the handles while keeping the tie rod connection angles aligned. Once the handles were drilled and bolted together, I had to drill one end of the tie rod that joined the two handles. I used a piece of wood and some duct tape to hold the two stick parallel while I was drilling the tie rod end.
