I spoke with one of our EAA members this weekend about how to finish the hinge pins ends. There are different ways to do this, but I like the way he did his. I bent one end at 90 deg and a small 30 - 45 deg in the other. I don't think it will be going anywhere. So I did this to the hinges on the rudder and elevator tonight. I also had to make an adjustment bend to ofset the brake handle so that it would catch the last notch on the flap bracket so I can use it as a parking brake. I finised installing the brake handle and the brake cable housing block. Drilled the two holes for the brake cable to go through the firewall.
