Brief Description: Mounting motor mount and landing gear legs
This afternoon I finished shimming the motor mount and installed all the mounting bolts. I installed the landing gear rods and axles. I need to order new bolts for the axles and landing gear rod due to a required service bulletin that was just released the end of June. I will leave these bolts in for the time being until the new ones are ordered. It looks like the brake housing is going to take a little time to get it to mount perpendicular to the axle. Not sure if anyone else had this problem or not but I need to look to see what others did. Sylvia came out to help out today and her pink duct tape came in handy as a safety marker on the right axle. I might just leave the axle off until the wheel is mounted so no one fall over it.
