Brief Description: Engine Build - Cylinder and Piston Assembly
I cleaned rocker arm assemblies and adjusted spacers for correct alignment with valve stems. It took me a little while to realize that the two mounting holes in the shaft of the rocker arm assembly will only seat completely down in one direction. This was not pointed out in the manual. I had to adjust the spacer a few times on each side.
