Brief Description: Engine Build - Cylinder and Piston Assembly
I cleaned the heads of any metal flakes that were left over from the machining that was done to add the extra set of spark plugs. I gave them a good bath in the sink and dried in the oven at 200 deg for about 30 min. Once dry I lubed the valve springs and valve stems.
