Sonex N367SX
Date:  4-9-2011
Manual Reference:  SNX-W07
Brief Description:  Left wing skin removal and deburring
This morning I installed a couple attic vents to help keep the garage a little cooler this summer. Our garage doesn’t have any insulation in the walls or in the attic so it is going to get a little toasty out there this summer.
I had a few holes that few holes that still needed to be up drilled before I could take the skins off and stat the deburring process. Once I drilling the last holes, I removed the upper aft skin and then drilled the remaining holes in the bell crank supports. I also drilled the center pilot hole for the tie down bolt in the lower aft skin. I had Sierra come out and help me flip the wing so I could remove the rest of the skins. I deburred the top side of the wing before calling it a day.
