Brief Description: Rivet the ribs to the left wing spars
Tonight I riveted the ribs to the left wing spars. I used the hand riveter to rivet the ribs to the main spar. It is a little tight to use the pneumatic riveter for this location. I also used a hollow rod that works great to tap the rivets into place. Some of the rivets are hard to insert by hand through the 5 layers of metal and the rod helps out a lot.
