Brief Description: Push rod assembly and wing tie down
Push rod assembly and wing tie down installation. Installing the push rod assemblies did not go as well as planned. The problems I had were that the treads on one of the push rods was messed up a little and the other was just trying to locate the appropriate hardware for this installation. I was not quite clear on the installation of the bushings that go in the push rod ends, so it is time to do some research on this matter. I am also going to make a shopping list of the missing hardware that I need to finish closing up the wing.
