I recruited a little extra help tonight installing the upper forward skin. The predrilled holes on the spar side aligned up perfectly. I was a little concerned with the amount o pressure that was required as I worked my way to the leading edge of the wing. But from everything I have read on other builder sites, this is normal. All of the extra skin seems to work out by the time you work your way to the leading edge.
