Attached the -02L right hand bellcrank pivot assembly, vertical channels, and angle clips to #9 SNX-W16-6 aft rib. I used some 2x4 and a square to help position the clips. This worked really well to help line up the clips with the top edge of the rib. I have found that the second section or piece always seems to go together better than the first.
