Now that all the parts I needed to complete the bellcrank assemblies came in, it was time to get started. It was a good thing that I ordered a little extra angle stock as I had to redo a couple of the pieces I made. For the most part I was happy with the outcome of the parts I had made. The brass bearing did not fit as tight as I wanted them to. I have heard of other folks using a little epoxy to help keep them from spinning. I think that is what I will do also. These took longer to fabricate than I thought they would but the second one went together a lot faster.
