Brief Description: Installed oil sensor and seatbelts
Tonight I drilled and tapped one of the cover plates that is suitable to mount the oil sender. I also installed the seatbelts except for the center straps. I need a 2 1/2 inch bolt that I am missing. I will pick one up at Lowes on the way home.
I almost forgot that I bent all the angles on the pieces for the engine baffle kit.
