Sonex N367SX
Date:  7-16-2012
Brief Description:  Engine Build - spark plug install
I cleaned the garage some and tried to make a little more room. Gapped and installed the eight spark plugs. There are two different types of ignition systems used for this engine, so the top spark plugs were gapped at .018 inch and the bottom four were gapped at .032 inch. I put anti-seize on the threads and torque to 22 ft lb.
