Sonex N367SX
Date:  6-11-2012
Brief Description:  Engine Build - Cylinder and Piston Assembly
Removed pistons from cylinders and removed rings from pistons so I could check ring gap. I used a ring expander tool to remove the rings and needless to say it took me a few tries to get the hang of it. All the rings checked out just fine. I used a scale to check the weight of each piston, pin, and ring set to see if they were within the 5 gram weight difference. Everything was fine as there was only 1 gram difference in the set.
