Sonex N367SX
Date:  4-16-2012
Brief Description:  Fuel tank prep
The fuel tank is an injected molded tank that has the fuel line fittings molded into the tank. During the process of making the tank there is some plastic that will make its way onto the threads of the fittings. I used a drill a size smaller than the opening of the fitting to clean out and then a tap to clean the threads.
