I spent some time tonight trying to figure out how I was going to make a gascolator mount. The gascolator had three mounting tabs that you could connect too. The way that I needed to mount it to the firewall was causing interference with one of them, so I had to eliminate that tab. A tray type mount is what I ended up deciding on. The tray would go around the gascolator and allow it to mount close to the firewall.
