Sonex N367SX
Date:  1-31-2012
Brief Description:  Instrument panel fabrication
After much thought, I have decided to use piano hinges to attach the instrument panel. This way I will be able to have access to the back of the panel by pulling three pin from the hinges. I had added the lower section so I can put the switches, breakers, audio jack, throttle, and mixture on it.
