Sonex N367SX
Date:  10-4-2011
Number of Hours:  1.50
Manual Reference:  SNX-C01
Brief Description:  Rudder cable installation
Tonight I ran the rudder cables thru the fuselage and attached to the rudder control arms. The white cable chases had to be removed from there housing in order for the cable to run thru them. The white sleeves are split in half so they can be put around the cable and then reinserted in to the housing. The white sleeves are held in place with a c-clip that was a little bit of a challenge to remove.
