Today I worked on attaching the horizontal stabilizer to the fuselage. A lot of fitting had to be done to get everything just right. I had to use the hand grinder and a file to clean up some areas so I could get full unobstructed movement of the control rod. As I have told said before, I think this horizontal stabilizer has been on and off 50 times. Patience is critical for sure.
