It was nice to have an extra set of hands out in the shop tonight. Sylvia got to use a tap for the first time on the fairing mounting hole that was pre drilled in the end of the axle. The other thing that we worked on was rounding the edges off of the brake pivot pin. The hardest part was getting the pin removed from the brake assembly. This is where the extra set of hand came in handy. I found out tonight when I was looking at tire and wheel assemblies that my kit came with the larger optional 5 - 5.00 wheels. This size is recommended if you plan on flying off of a grass landing strip. This was a pleasant surprise.
