Adjusted the landing gear axles at a 7 deg toe-in by using a 3/4 inch spacer on the inside of the axle. Once everything was locked into place and double checked, I used a drill to mark the hole that need to be drilled in the landing gear rods. I removed the rods and now ready to drill the final two holes.
