Brief Description: Deburring and dimpling of the right wing.
I spent some time today dimpling the forward ribs that are going to receive flush rivets. I had to grind a little bit off of the bottom die, so I could get closer to the inside edge of the ribs for some of the holes. I wished I would have used a smaller drill bit to drill the holes on the forward ribs because the dimpling die open the hole up a little bit. After noticing this, I made a couple of practice samples and realized that it would work best if I did not fully compress the dies when dimpling. I also did a lot more deburring today as well.
