All that is left now is to safety wire the parking brake mounting bolts, add 1/4" flexible vinyl tubing spacers for cushioning effect, double check the tightness of all fittings, then start filling the brake system. I am considering using Mobil Synthetic ATF fluid just like several other builders on the field and on VAF are doing.
