I used the band saw to cut out the lens. That worked real well. 3M wheel buffed out any stress risers and smoothed the sides to the final dimension. Paint tape on both sides protects the cutting, fitting, and drilling process. With the wingtip off, I was able to apply great pressure from inside to push the lens into position and drill the 3 holes in the top. Then repeated with great pressure to drill the bottom 3 holes. It went well. When I went from 40 to 30 drill bit I removed the tape that was between the wing skin and the lens to get an even tighter match.
